Has anyone been playing with a new 2018 mustang with the Roush OS and tune? Full speed density with a map sensor and no maf now. One thing I noticed is the cam timing is fixed on the exhaust at 15degrees and 0 degrees on the intake. The actual inlet isn't even commanding 0 degrees but it is a flat table which seems strange. They also have the max timing advance and retard 0 degrees from 6500rpm up. Its almost like the tune was a rush job to get it on the market? I also have a large dip in power like it hits a torque limit at around 5000rpm, it pulls about 6 or 7degrees and then it feeds it back in almost instantly. The driver demand table is also strange, half the table looks normal down low then in high tps its almost inverse with 900nm at low rpm tapering down to about 480nm at max rpm? Some of the bi model exhaust tables also appear to be labled wrong.
