Everything seems fine with the tune as far as the NB goes, but when I go WOT, it shoots straight to 8 afr, probably would go less but 8 is the limit. I am concerned that this is not accurate although cruising it is at a constant 13.5-15.5ish... normal.
The config I am using is (2.3750*([7101.10])+7.3125, I have it wired through the AC pressure sensor.
Does the config seem correct or is the sensor maybe in need of a recalibration?
