Results 1 to 11 of 11
Thread: 2016 Camaro Nitrous
    May 2016
    valley
    10
    2016 Camaro Nitrous
    looking to spray my 2016 camaro headers robofab flex fuel gonna spray a 100shot already have jets set for e85...looking for tips on tuning it
    will i have to adjust vt, driver demand tables? any advice is appriciated
    Dec 2015
    Miami,Fl.
    290
    Good luck.
    There's no way of telling the engine where the extra power is coming from so when you exceed all the commanded torques, it's gonna shut the throttle on you.
    2023 Ford Maverick 2.0T AWD
    Aug 2009
    Calibrating
    3,373
    I?ve done several nitrous cars... little tricky with these, but you can still keep the TB open (or Atleast I have on 200 shots)
    Dec 2015
    Miami,Fl.
    290
    Auto or manual?
    Aug 2009
    Calibrating
    3,373
    Manual cars for sure easier.. trans Tq request doesn?t matter.. but nitrous setups I?ve done 2 ways.. increase DD/peak Tq OR leave it alone and just add the nitrous on the same tune and leave Tq model stock (adjust timing on each, depending on octane)
    But on gen 5s I like doing a separate nitrous tune and make the Tq model reflect the nitrous (make commanded Tq more accurate for trans/TB control and no need to have any timing retard box)
    Dec 2015
    Miami,Fl.
    290
    Yup that's what it comes down to. Gen 5 auto with a dedicated nitrous tune off bottle will drive and shift like shit. Having to write two different calibrations sucks in my opinion. Can't be like back in the days with Gen 3/4s where you just hit the switch to activate your timing box crack open the bottle while driving down the road in "mexico" and letting the motor rip.
    Have you faced a problem were the injectors pulse width and cylinder air mass decrease (only when the nitrous is on) causing car to go lean ?
    Aug 2009
    Calibrating
    3,373
    I have not
    Oct 2013
    211
    I have seen this before but it has never caused a lean issue. it does put you in a lower airmass part of the timing table so you have to be careful there.
    Dec 2012
    235
    I was just curious, why can't you parallel into the Iat sensor wire, from the Nitrous solenoid with a resistor that sends it to approx 250* Iat and tune timing retard there? Do the new ecm's not like that?
    Aug 2019
    22
    Sooo I'm running a 75 shot and my trans is slipping after shifts. Do I increase the VTT at WOT 75 ft. lbs. to solve this? Or would this cause a throttle shut because its not measuring this torque?
