Results 1 to 15 of 15
Thread: 2016 Camaro Fuel pump Voltage
    May 2017
    North Florida
    80
    I have a 2016 Camaro 2ss A8 with the zl1 low side in tank fuel pump. I have been seeing where a boost a pump is being installed to increase voltage to increase pressure. I came across an article that stated HP tuners can now increase voltage via tuning. Is this true? If so how and where is this found in HP tuners? Would you be able to command a higher normal voltage then as you go wot raise the peak voltage currently in the stock tune? That way you don't get the fluctuations. Also be able to use zl1 pump more affectivly.
    May 2007
    489
    You will have to license the fuel pump module in order to make any changes to it.
    May 2017
    North Florida
    80
    Quote Originally Posted by Sneakyws6 View Post
    I have already done that. I was just asking where and what needs to be changed and if it is even possible.
    May 2017
    North Florida
    80
    I guess this is either not being used or the guys using it are be very quiet about it.
    May 2007
    489
    i am going with trade secret quiet. Even the shop I used barely mentioned unlocking the FPPM and said they rarely tune it on their builds. This was when I was adding a PC D1SC to my 2017 Camaro SS M6 1LE and was offering to put the LT4 high side fuel pump and injectors in the car with the hope of avoiding using meth injection.
    Tuner Camaro6's Avatar
    Jun 2018
    Chicagoland
    135
    Quote Originally Posted by Brianw36 View Post
    ECM program - systems, general, then change
    - diag sys voltage low 12.5v
    - diag system boost voltage 14.6v
    - diag system boost max 10min (change this to minutes)
    Fuel System - max desired pressure if you need more pressure I have 81.2 (0-222.2), 80.9, 79.3, 77.2, 74.3, 72.5 (277.8-444.5)
    I assume all the parameters are already changed for the ZL1 low side pump? ECM & FSCM modules?
    I just looked a 100% WOT log that I went from 1st-5th gear and pressure was 64 -67 steady and peaked at 81 when I paddle shifted the A8.
    Hi Side was still at 2,932psi & 6,479rpm when I shifted into 5th gear.
    14.8v system power
    9psi boost with LT4 S/C on a LT1 2018 Camaro SS
    May 2017
    North Florida
    80
    Quote Originally Posted by Camaro6 View Post
    14.8v system power
    Thanks for the information. I will give it a try.
    May 2017
    North Florida
    80
    Camaro6. Do you have lt4 injectors and hsfp along with the zl1 intank pump? I pulled a stock zl1 tune and looked at fuel pressures you use, and they match the zl1 settings. I have zl1 intank pump and a 38% fuel lobe cam. Stock injectors and high side.
    Jun 2018
    Chicagoland
    135
    Sorry, just noticed the post. Yes LT4 inj, hopfp, and zli intank. stock cam, no fuel lobe.
    Jun 2007
    Close to my Z06
    271
    No issues with the pump running the extra volts?
    Jun 2018
    Chicagoland
    135
    Quote Originally Posted by HNK View Post
    Nope and over 20k miles since the LT4 conversion.
    2018 Camaro SS, LT4 Fuel System, LT4 S/C
    2020 Ford Edge ST (93-E85 flex fuel tune)
    1999 Pontiac Firehawk
    1987 Chevy Caprice, 6.0L TT 4L80 AWD
    ***Only AWD box chevy in the world***
    Next Level Tuning and Performance
    Tuning email: [email protected]
    Jun 2007
    Close to my Z06
    271
    what Voltage are u running at the higher flow areas?
    Jun 2018
    Chicagoland
    135
    Last 2 items to the right are 15.8v, to the left of it 15.5v (pretty sure stock was 15.5v all the way to the right) It's been awhile and not in front of my tune currently to check. I just know what to change when doing it in front of me. I did bump my HPFP setting up a bit with the cold weather and E85 fuel I do run at times. Depending on what you're doing, injection timing plays a role as well.
    Sep 2018
    14.8v system power
    14.8v system power
    Sorry to bring up an old thread. Is what you have above what the settings should/need to be set at to use the ZL1 low side pump on an Camaro SS? I am getting ready to install mine and am hoping not to have to pay my tuner to get me set up correctly to run the ZL1 pump if at all possible. Any help would be greatly appreciated.
    Jan 2020
    8
    Don?t install a ZL1 fuel pump put in a Boost a pump and change your fuel pump duty cycles to 100%. You?ll be into over 700rwhp WITHOUT the bandage known as meth.
