Results 1 to 5 of 5
Thread: Understanding Injector Flow rates
    May 2018
    24
    Hi All,
    I know this may be a noobie question but could I get an explanation on what determines the Low and High fuel flow rates.
    So far I understand that the Low Flow is basically idle and part cruise throttle High Flow is WOT.
    I have xspurt 1000cc injectors... having trouble finding the factory data for these. Based on the ID1000 table all I can see is aprox 1015cc/min @ 58psi is what I should be working too. But how to calculate what is the High and Low slope from this.? I need to add fuel as im currently running lean...
    Any helpful tips would be great.
    May 2018
    24
    Ok so done some more digging this afternoon. I now found the ID characterisation tables for Ford. Seems to have answered my questions from earlier.
    So now just so I've got it clear in my head. To richen the AFR I lower the Number in the Hi/Low flow table.??
    May 2018
    24
    So I found this: http://www.efidynotuning.com/fuel.htm
    Thanks to some more digging through these forums from some very old posts, its all making more sense now.
    Jun 2018
    8
    Yes lowering the injector slope numbers adds fuel and raising the numbers takes fuel.
    Feb 2015
    Perth, Australia
    974
    700rwhp_22psi.hpt BF 1000cc xspurt
    15psi run in inj pw change.hpt BF 1000cc ID
    490rwhpfinal.hpt FG 1000cc xspurt/bosch
    note the battery offset tables too.
