I am having a hard time finding the limiter preventing shifting above 7400 rpm. Any ideas?
E85?
You are lucky - EU tunes won't shift above 6500 rpm unless using paddles - support says there's nothing extra to decode...frustrating.
v-performance.pl/
facebook.com/veee.performance/
https://www.instagram.com/v.performance.pl/
Remote tuning:
[email protected]
+48 697276579
I cant imagine..........Need all that rpm
For me it will always up-shit @ 6500 rpm no matter what is commanded or which drive mode used.
v-performance.pl/
Remote tuning:
[email protected]
+48 697276579
Did support verify that is the limit? That was the first hurdle I had, 6500
Nope, they said there's nothing extra in EU tune that can cause it. I tried everything - there's either something not available or something that I'm missing.
What did you do to shift it over 6500?
v-performance.pl/
Remote tuning:
[email protected]
+48 697276579
This is not a file I would run around on. Multiple issue with it and downshifting is spastic. If you can compare with the EU tune and it fixes your issue let me know. I will send a good file to you.
Nope, nothing new. Tried raising all shift tables a lot - still nothing.
v-performance.pl/
Remote tuning:
[email protected]
+48 697276579
What limits is it hitting? Source?
It hits nothing - it would just up-shit @6500 rpm like nothing ever happened.
v-performance.pl/
Remote tuning:
[email protected]
+48 697276579
What rpm does it shift at stock?
Restore table 40070 to stock?
Stock shifts @6500 - I was not able to modify that.
v-performance.pl/
Remote tuning:
[email protected]
+48 697276579
I would be interested in comparing your tune or the base tune file.
Possibly high pressure pump speed limit under fuel pump tab?
v-performance.pl/
Remote tuning:
[email protected]
+48 697276579
If traction control is not fully off it will short shift every gear even if you are no longer spinning tire. Also raise transmission protection, transfer case protection, and trans IPC.
v-performance.pl/
Remote tuning:
[email protected]
+48 697276579
