Originally Posted by
Greg Powrie
Thanks for the response. I delete intake map sae from the channel list. I am using pressure ratio under engine-airflow-volumetric efficiency. I have been working on the torque table a bit. I have noticed that it seems that everything seems to affect the torque model. I thought at this point it would make more since to tune the vve before going too on the torque tables. I bought the tuning school books for the gen 5. They get the car running but its less than perfect. They don't explain what any of the changes are doing really just what to change and how much.
Also I just went back through the logs with the failed MAF and noticed the cylinder airmass changed significantly at idle.
it was idling at .58 where its normally around .27 in MAF only. I didn't change that area of the timing table as it never touched it until failing the maf. I think I can alter that area of the timing table and get the car to run so that I can work on the vve. I don't see why the airmass should have gone up or changed significantly failing the maf.
