Results 1 to 4 of 4
Thread: 6L90 to 6L80 Express VAN 8.1L E38 2013
    Oct 2015
    2
    Hello there! How are you doing?
    So I changed the transmission hoping to get it working just by changing the VIN... did not work... so after a lot of reading I discovered that I need to find a compatible OS. Either on Chevrolet TIS or a set of hptuner files.
    Does anybody have the pair for this combo? Could not find it on the repository. I attached the read of the current ECM and TCM modules.
    Lectura ECM y TCM.hpt
    Thanks!
    E38 OS is 12654075
    T43 OS is 24270599
    Oct 2013
    550
    E38 OS 12654075 was used by 2013 Express vans.
    T43 OS 24270599 was used by 2014 Corvette and 2014+ Trucks with Gen 5 DI engines (E92 ECM).
    Your 2013 Express van would have originally used T43 OS 24265260.
    Oct 2015
    2
    Thank you very much!
    So, do you think I could have READ the original T43 from the 6L90, then write on the 6L80 TCM and everything would have work perfect?
    And if I can't get the old TCM, I can use TIS to write the 24265260 and everything should work? Thanks again!
    Mar 2015
    Mission Hills, CA
    13
    I'm here to know what happened. I have the same problem, same T43 OS but the operating system of the ECM e38 is: 12639835
