Originally Posted by
Thatwhite5.0
I believe it was a combination of a AFR that was too lean and fuel torque reduction played a role. They were heating up cylinder 8 with a lean mixture and then when they had torque reduction due to rev limiter or a parameter set incorrect, their top end completely cut fuel.
There was a flaw in the build of the 5.0 block. Cylinder 8 ran hot due to lack of channels for coolant to flow. MMR has a "head cooling mod," I believe that's what it's called. I haven't heard of cyilinder 8 failures of that type in any other year than 2011. True stock 2011 were having this failure. Stock.
I've ran 32 degrees and even tested 35 degrees on 95 octane fuel. On 91 octane, I've ran a good 27 - 29 degrees with no knock. 85k on this motor with countless 8000 RPM shifts.
I have my fuel torque ratio zeroed out. [ECM] 44775 to disabled torque reduction via fuel cut.
