Results 1 to 20 of 34
Thread: Dual cp3 tuning with Y harness
    Advanced Tuner MAIDENCR's Avatar
    Sep 2018
    Quebec,canada
    207
    Anybody have some hint to tune a dual cp3 with Y harness? Tried some stuff but it always goes up to 26000psi
    Did you double the FCA amperage? That would be the first place to start.
    Sep 2018
    Quebec,canada
    207
    Max dc current in stock tune os 1,700...tried to enter 3,400 and a warning came up...the it only enter 3,000
    03 cummins,175% flux injectors,dual cp3,s467.7/83 1.00
    Nv5600 with valair triple disc clutch
    when does it go to 26k rail?
    Sep 2018
    Quebec,canada
    207
    At idle
    Have you logged FCA current and duty cycle at idle?
    Sep 2018
    Quebec,canada
    207
    Dont have duty cycle but current is 1.026mA
    for some reason the ecm is asking for full rail. If it was at 3000 and still at 26k then it would be an issue. Is that the only change you made, was put in the splitter and then try to double fca amperage? Something doesn't seem right.
    Sep 2018
    Quebec,canada
    207
    In fact i have some tuning by a professionnal tuner....but truck smoke a lot and he doesnt seams to want to tune it better..im sick to pay for a tuning and dont have full support...other tuner i had before have clean tune but take a mount or so to answer if he answer...so wanna try some tuning...you pay arround to 400$ us...2-3 retune then they let you with what you have...
    It is unfortunate how some of the "pro" tuners are, sorry to hear of your troubles. Did you tell the tuner about the splitter? Maybe he can send you a new tune.
    Sep 2018
    Quebec,canada
    207
    truck have the "appropriate" tuning for dual cp3....but at some tps level and acceleration it smoke a lot...but my tuner say i need fuel to light the turbo...but it spool easier and faster when you go easy on throttle...
    Sep 2018
    Quebec,canada
    207
    Got it idling today...but pressure go way to high with a blip of the throttle...
    Sep 2018
    Quote Originally Posted by MAIDENCR View Post
    http://fleeceperformance.com/dodge/2...2-harness.html
    This might help?
    Keep adding amperage if it continues to spike in the range where it is spiking.
    Sep 2018
    Quebec,canada
    207
    Its the Y harness i have...
    Will try add some amp
    Dec 2015
    43
    On the DC to Current table, start with multiplying each value by 1.7. Adjust from there. eg. 1700 X 1.7 = 2890.
    Sep 2018
    Quebec,canada
    207
    Did another test today...idle nice and smooth...i can drive it....but when accelerating the rail pressure "bounce" like shuttering...any idea?
    Banned
    Jan 2018
    Everywhere
    1,772
    I had that before, after getting an II 85% over cp3 and 120hp injectors and running a smarty s-06 before custom tuning started coming out for it. Once custom tuning started coming out, Smoothing out rail pressure where I had those shuttering spikes occurred in the rp map cleared it up. I only had it in certain parts of the map.
    Sep 2018
    Quebec,canada
    207
    Did another test today.....but when i let off the throttle my rail pressure drop below the desired? any hint? here is the datalog to see it
    im unable to add a picture.....why?
    Sep 2018
    Quebec,canada
    207
    Attachment 83459
    here we go
