Here's the rundown:
64 chevelle
02 LQ4, stock bottom end, stock heads
LS6 intake w/ 02 LQ4 DBW throttle body, 33lb flex fuel injectors, returnless fuel system
Elgin E1839P cam (220/224, 112 LSA, .575" lift), PAC1218 springs
dual AEM 30-4100 widebands acting as narrowbands for o2 readings to ECM
2005 0411 ECM green/blue
T56
Car runs good, I still need to tune the fuel, had tuned for a bad fuel pump earlier and haven't had a chance to get back into it.
Cruising down the road the car will go to ~16:1 AFR for a little bit, then switch back to toggling 14.7, then drop down to ~13:1 for a while. I cannot figure out what's causing this to happen the ecm is actually commanding this AFR.
In the scan it starts to show the behavior around 6:43
Attaching tune, log, etc. Any help would be greatly appreciated.12-Salty-33lbinj-injectortuning.hpt9-6-tune12-home2WORK.hplsalty4.Channels.xml
