Results 1 to 4 of 4
Thread: Is my WB working?
    Is my WB working?
    I have my wideband(LC-1) hooked up , have it programmed to Responce speed 1/6 and thats what Im getting. Anyone can have a quick look and say if everything is cool and I can start tuning now?
    Also it replaces O2 B2S1 if its matter.
    www.turbofirebird.com tuned with HPT MPVI Pro, LC-1.
    Nov 2005
    Someplace high in the Himalayas
    770
    You are way lean if that's right and your seeing knock. Be careful.
    www.outlawpontiacdragseries.com
    Come race with us in MA, PA, and VA!
    2005 GTO A4 - Spintech X-pipe with Powerstick mufflers, IAT relocate, Volant, !scoops, !cowlgasket, !skid plate, LM-1, HPT2.0/MPVI Pro USB, 275x40x17 Nitto DR, rolled fenders, Pedders 2985 springs, Britax baby seat with 5 point harness.
    Stock:13.36@104
    Mods in sig:[email protected]
    Nov 2004
    231
    your wideband looks like its working ok as it is reading around 14.7 when your in cloosed loop but as purplepiss said be really carefully man. your afr are REALLY lean when you go WOT. Richen up the pe or ve table before your do so serious damage. also check that you dont have any exhaust leaks before the wb sensor as that will also make it read lean
    Your fuel trims are way off as well, disable your maf and tune the ve table before you go any further
    04 VY Commodore ute M6 ls1, 918 valve springs, TR6 plugs, genttrbb twin turbo kit, 60lb seimiens injectors, Bosh 044 fuel pump, SX fuel reg, PLX wideband,Full Castle Hill Exhaust with 2 1/2in dump pipes, 4in cats into twin 3in cat back (no merge), Ripshift, oz700 clutch and 3.73 diff gears
    there is def no leaks, it is installed in manifold. So , my plan is
    Richen up PE
    Tune VE in SD
    Tune MAF
