Results 1 to 4 of 4
Thread: Immediate Engine Torque Source - Axle.. Can we please have Gains -> TM Spark
    Nov 2006
    2,757
    First, I don't think GM does a good job at this on factory cars/tunes. Someone should be beat with a cane for letting some of these new cars leave driving so poorly.
    The problem is after leaving a prolonged idle or while using rev matching; Immediate Engine Torque Source will change to axle and in that mode specifically the TM Spark advance corrections are entirely too aggressive. If you creep a Gen 5 car around in a parking lot you'll feel it either dragging like the brake is on or you'll get what feels like fast torque exit on gen 4 cars. Its quite literally a TM induced bucking. The timing will bounce some 20 degrees and when the mode returns to none it goes from subtracting 20d to nothing giving you a bang.
    We can fix this by limiting by setting TM spark minimums higher but this is not a good fix because there are other TM's that should be allowed to pull the full amount.
    Can we please have the gains to this torque management? Maybe it is a look up table torque error vs. retard? IDK
    Tuner at PCMofnc.com
    Oct 2014
    Alfred, Maine
    19
    I'm having the same issue with my 17 Silverado... Have you figured anything out?
    Nov 2006
    2,757
    This particular car (C7 vette) had mismatching front and rear tire sizes. Not factory. I never could get it to act right. I think it thought you where slipping the clutch with the front/rear speed mismatch.
    May 2003
    South FL
    1,376
    Virtual Torque is where you influence this behavior. Minimum Spark is just the "floor" that Torque Management Advance is allowed to reduce torque(via timing) to reach target torque requests.
    [email protected]
    Owner/GM Calibrator
