Can someone help me with my issue have a 2011 Camaro ss 6.2 auto stock engine with pro charger done the 2 bar sd os swap I didn?t read or write anything with the fuel pump controller not sure if that?s my issue or not so after swap I write entire make some ve tables and try to crank car I?ll crank and run for few seconds then the airmass falls to zero and engine shuts off air fuel when this happens is 11.0 ish spark low 20?s do I need to disable the mass or or anything else causing this to shut down
