Hi
I'm working a strange project of putting a ecotec LE5 into a miata. I have the physical part almost complete and have the wiring worked out, but now am stuck on getting the computer to run.
I have a junkyard GM E67 ECU from a 6 cylinder vehicle that I'm trying to reprogram to a 4 cylinder vehicle for my engine. I read the ECU and then wrote a change back to it to license the physical unit to my HP Tuner ID. I then downloaded a base map from the HP Tuner site for the correct 4 cylinder engine and licensed it also to my HP Tuner ID. I wrote this file to the ECU which appears to have taken the change, but now I'm unable to make changes to the ECU as it's telling me the ECU is unlicensed. Clearly I've messed something up, but used up 4 HP credit along the way! Ugh
I contacted HP Tuner support who told me that I need to bring the car to a dealer to have them change something, but since the engine is in a non-Chevy car running stand alone, I can't imagine what their reaction would be. Also there's the issue of getting it there...
So now I purchased a second E67 unit from a Cadillac DTS 4.6 which I'd like to reprogram to a 4cyl config to get the engine running. Before I use 2 more credits licensing this E67, I'm looking for some guidance on how to correctly perform this task. I can't find any guide/instructions on how to do this. Can someone quickly walk me through how to do this?
Or maybe someone has ideas on how to unlock the first ECU?
Thank you in advance!
