SO.....ever since we got this 03 ive noticed in the cooler months the rail pressure goes down. It did it with the smarty tuning, and it is doing it with the tune i have in it now.
I suspect heavily it has alot to do with IAT. I logged it with about 21 degrees(C) IAT and all is good. Logged it with about 12 degrees(C) IAT and the RP is aprox 5000psi from commanded under very similar driving conditions. I've been trying to wrap my head around the correction and multipliers associated with rail psi but am hitting a wall
Is there a equation that someone can explain to me on how they control/modify the desired rail pressure table? Both my transient and low air density maps are the same for the DRP.
Attached are the logs i am using to track this down.
