Results 1 to 8 of 8
Thread: Camaro SS LS3 Nitrous Timing
    Feb 2018
    Arizona
    19
    im in the process on installing a nitrous kit on my camaro ss. mods are night fury cam, e85, long tubes, full e85 and full exhaust.
    right now with the N/A tune i know timing its advance. question is how much timing should be removed for a 150-175 shot. timing at the moment is 25.5'. i know with e85 since its better than 91 octane you need less timing removed. how much timing should i start with? -4, -5? fuel pressure is 60psi. at high rpms (5k-6700rpm) it drops down to 50psi. pump duty cycle is at 90%. i also have the zl1 pump. any advice is welcome. thank you
    2011 Camaro 2SS Ls3 6spd manual
    Night fury cam/stock heads
    E85 /ZL1 Pump, 80lb injectors
    3.45 gears
    Apr 2011
    Chicago, IL
    763
    I believe its 2 degrees removed for every 100shot so maybe start with 4 or 5 degrees removed to start
    Chicago
    49
    I believe its 2 degrees every 50hp. I would pull 8 degrees to be safe. make a pass and pull the plugs and look at the strap.
    Apr 2011
    Chicago, IL
    763
    Gbnoobie is right ....sorry yeah 2 degrees for every 50
    Feb 2018
    Arizona
    19
    Even for e85? I know with gas its 2 degrees per 50 shot but e85 shouldnt it be less? And afrs safely at what range should they be at? 11.5? 12.0? At the moment on the n/a tune its set at 12.5-13.0
    3.45 gears
    Apr 2011
    Chicago, IL
    763
    well yeah you can probably get away with removing less but why not be safe about it first just to make sure nothing bad happens
    but whats going on with the fuel pressure dropping situation - that shouldn't be so id say before anything make sure the fuel system can handle the nitrous - FP should remain at 58psi
    Feb 2018
    Arizona
    19
    Quote Originally Posted by TCSS07 View Post
    Oh okay i see what you mean. And thats whats worrying me too. That at high rpms it drops down to 50psi. Duty cycle is 90%. Was thinking on putting it at 100% so pressure would stay stabled and go from there.
    3.45 gears
    Jan 2019
    34
    anything happen with this?
