Results 1 to 5 of 5
Thread: updating injectors on E38 Camaro
    Jun 2018
    603
    So I'm trying to add some new injectors from FIC (clinic) on a Camaro SS. They provided data but the Flow rate vs pressure delta numbers don't match up. The ecm lists psi but the FIC charts list KPA. How do we correct for this. I can change the flow rate to lb/h like the FIC chart but it won't let me change the units on the pressure side.
    Senior Tuner mowton's Avatar
    Mar 2007
    Florida
    3,773
    Right Click on the Pressure Delta flow rate cells, select Column Axis, select Units, change to kPa
    Ed M
    [email protected]
    Jun 2018
    603
    Thanks for the quick answer. I knew it was an easy fix like that.
    Jun 2018
    603
    Also, does anything need to be changed in the fuel system section? I found a duplicate flow rate vs pressure table over there.
    Mar 2007
    Florida
    3,773
    That is for the Fuel Pressure Control Module (FPCM) and my understanding is it doesn't need to be changed.
    Ed M
    [email protected]
