I started to tune my truck....start and run "fine" if im easy on it.....if i ask for more power i have some spike in actual rail pressure while desired ramp up.....and when I let the throttle off pressure fall of really low...sometime engine stall....sometime i need to shut it off and restart it....and pressure is ok....push it a little bit then loose pressure...i joint a datalog
test4.hpl
