Results 1 to 8 of 8
Thread: desired vs actual rail pressure issue
    Advanced Tuner MAIDENCR's Avatar
    Sep 2018
    Quebec,canada
    208
    I started to tune my truck....start and run "fine" if im easy on it.....if i ask for more power i have some spike in actual rail pressure while desired ramp up.....and when I let the throttle off pressure fall of really low...sometime engine stall....sometime i need to shut it off and restart it....and pressure is ok....push it a little bit then loose pressure...i joint a datalog
    test4.hpl
    03 cummins,175% flux injectors,dual cp3,s467.7/83 1.00
    Nv5600 with valair triple disc clutch
    Sep 2018
    Quebec,canada
    208
    Banned
    Jan 2018
    Everywhere
    1,772
    Have you modified your fca duty cycle and current maps?
    Sep 2018
    Quebec,canada
    208
    Yes...but the duty cycle may be not correct
    Sep 2018
    Quebec,canada
    208
    You know how Jim P??
    Banned
    Jan 2018
    Everywhere
    1,772
    No experience tuning dual cp3, I would follow what Paul B said in your other post in regards to duty cycle to current. As far as base duty cycle map, again no experience with dual cp3 tuning. Hopefully someone with that experience can chime in
    Oct 2018
    Bernville, PA
    1
    Maidencr, did you get this figured out yet? If not I can help. Email me @ [email protected]
    Jon
    Sep 2018
    Quebec,canada
    208
    Email sent
