Results 1 to 3 of 3
Thread: Delivered Engine Torque - vs Stoich entered - MAF/VE - Ethanol
    Aug 2010
    215
    Hey everyone!
    I have a question, as it relates to Delivered Engine Torque, GCyl and Stoich.
    Scenario: E60 tuned well, MAF/VE is good, everything is fine. Delivered Engine TQ = 500 GCyl = .86
    Scenario 2: E85, ONLY thing changed is stoich. Delivered Engine TQ = 560 GCyl - .90
    The above scenario can be visa versa. For example, E60 could have the higher numbers than E85.
    I presume with a good tune on one fuel, changing stoich is all that you should need to do, so that the Delivered Engine TQ or GCyl numbers ARE NOT skewed. Correct?
    Aug 2010
    215
    I failed to mention I added fuel via power enrichment when I saw the gain.
    Basically if delivered engine torque is higher without touching MAF or VE, only PE.....and gcyl and DET goes up, that means a power increase....correct?
    Australia
    1,982
    i dont have the option on mine but have seen others with the virtual torque and there is a whole section for e85 same as the petrol so u can set up torque calc for each fuel, ethanol should have more torque
