3800 V6 "Parameter out of range" Spark / Retard/ Rate High Load
1999 3800 Lumina P04 ECM / 9374963 OS
1997 3800 GP P04 ECM / 16243643 OS
Having issues with parameters out of range.
Spark / Retard/ Rate High Load (or Rate Low Load)
Cannot input a value less than 256, and if you do, it changes it to 256 and cannot undo. Even "stock" values have become out of range.
The limit range when you "hover" over is 256 - 62640. The stock values in most operating systems are not even in that range, so something seems to have gone awry with the latest editors:
VCM Editor 4.0.12
VCM Editor 4.1.494 Beta
Screenshots of problem:
1st file has problem, 2nd file (2000 Camaro L36 3800) is OK.
I have problem with IFR table limits also (contacted support), so was wondering if I might run into other limit issues on 3800 platforms with Editor 4.0 or 4.1?
Start a support ticket on hptuners.con and they should fix it in and release it a beta for you I had similar issues with my 2004 impala ss and they fixed it pretty quickly.
