Results 1 to 2 of 2
Thread: Help with logging 6T70 shift issues
    May 2018
    Seattle
    3
    I'm hoping someone on the forum here might be interested in helping analyze transmission logs / provide feedback
    I'm not sure about what I should be logging - any help here would be great. If there are some guides please link them, I like details, feel free to explain things in detail.
    I posted this question over on the VCM Scanner forum a week ago, but got no replies.
    Back story:
    I have a 2013 Impala with the LFX engine and 6T70 transmission. Bought the car a couple years ago with 42k miles, trans fluid was dark, had it flushed by a reputable transmission shop, and I can confirm they put the right fluid in - Dex VI (synthetic).
    Issue 1) Under light acceleration from a stop, I can feel several short hesitations, best I can tell this occurs in 3rd gear. It feels like the transmission is preparing or starting to shift and then doesn't, 3, 4 or several attempts later it will complete the shift.
    Issue 2) 3rd to 4th is sometimes a hard shift - often after issue 1 above has been occurring, and if I have accelerated moderately to hard then lifted off before 3rd to 4th shift - e.g. winding up to 35 to 45mph quickly to merge in traffic from a stop.
    Both issues do not happen with moderate to heavy acceleration, everything is normal. But will also occur if I have gone from moderate to heavy acceleration, then lifted off the accelerator to light throttle or coasting.
    If I disconnect the battery to clear anything learned, transmission performs nicely, with less "slop" in the shifts until the adaptives are set/learned again and the issues come back. Quite honestly I think the car performs and drives better before the adaptives are set - everything feels tight, responsive and on-point, which seems backwards to me.
    2013 Impala LTZ. 3.6 LFX.
    2002 Impala LS. 3800 Series II, OverKill 91 Tune, Shift Kit, Allison TES 295 fluid, BRISK GOR17LGS Plugs.
    Tuner ZeroBoostBuick's Avatar
    Aug 2008
    S.W. Ontario Canada
    125
    In my opinion it's 1 of 3 different things (or 2 of 3 things )
    1. Fluid level too high
    2. Fluid level too low
    3. Shit fluid that doesn't hold proper viscosity when warmed up.
    Here is a video that shows how to check the fluid level on GM's Dipstick-less transaxles...
    https://www.youtube.com/watch?v=WPGwvwrGPlc&t=325s
