Members please,
We are in the final stage and just wanna have this setup running. L77 and 6l80 pulled from a 2012 caprice.
Solved
Members please,
Solved
I'm not on the right computer to view the tune but if you disabled both the VATS drop downs under the OS tab, then did a write entire that should have disabled it. Only a write entire will work, write calibration won't.
Hi there,
I'm completting same sort of project,
seem to be having same issues as you,
ive checked vats etc all disabled.
can i asked what you do to over come the issue?
thanks
regards
Paul
bump, having similar issues. Seems fuel is working, but i cant seem to confirm spark.
