Results 1 to 10 of 10
Thread: STFT doing wacky things at idle....
    The car is a 2014 Camaro SS, the combo is nothing new.
    LS3 (sbe)
    LS9 cam
    whipple 2.9
    long tube headers
    The STFT at idle are split B1S1 reads +3.1 or so B2S2 reads +30.5 I have attached a scan and the tune. Any help would be great.
    sub. I had one doing this as well.
    2008 Corvette
    UPP Twin turbo T4 67mm BB billet wheel kit
    427 LME Billet Setup
    Fore Innovations Triple 465 L4 Setup
    FIC 2150 injectors
    RPM TH400/9 inch
    Pro Torque Bolt Together Converter
    MaxxECU Stand Alone
    Oct 2013
    211
    If you know the injectors are good, start with the O2 sensors or look for a vacuum leak.
    I know the injectors are good, I checked and confirmed no vacuum leaks. The strange thing is the problem is only at idle, during normal driving they are fine.
    Aug 2006
    Arizona
    244
    Check for vacuum leaks and misfires
    2009.5 PBM G8 GXP M6 W/Roof-Self tune, OBX LTs, Kooks axleback, LSA blower, cam,
    Monster LT1-SC clutch, flex fuel, 12 psi [email protected] 1,800 D.A
    2007 TBSS-Self tune, bolt ons [email protected], 1,900 D.A
    1991 GMC Syclone- Self tune/catback 12.8@104, 4,200ft D.A
    As I said in my pervious post, I confirmed no vacuum leaks.
    any chance the o2 is getting cold and drifting? it's a old obd1 issue that we used to see with 1 wire o2's in headers. maybe the heater in the o2 died?
    just throwing things out
    Sep 2018
    213
    I had a similar issue. It ended up being an exhaust leak.
    Similar issue in a different car, was an exhaust leak.
    Senior Tuner mbray01's Avatar
    Dec 2013
    Slidell, La.
    1,015
    Exhaust leak!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    Michael Bray
    Rusty Knuckle Garage
    Slidell, Louisiana
    20yr Master Tech.
    Advanced Level Specialist
    GM World Class Technician
    Shop Owner
