Results 1 to 2 of 2
Thread: maf seems to be used under the 4k enabled 3.9k disable
    tuning maf only I ran into a bucking at light throttle going down a small grade on the interstate around 2800hz is what it cruises at at 70. but I can feel it at almost any speed and rpm if I try. I couldn't tune it out, but said eh. it won't be used below 3900hz anyways. so I re-enabled everything and the bucking isn't nearly as bad but still there. ve only is butter smooth. the bucking doesn't really show up in logs, but I figured it's just maf turblance. since it's got a ram air style intake.
    any way to get this thing to not use maf under say 3k hz?
    just to add, this is a dead stock ls3. like air box only, still even has cats. just trying to get uses to tuning while it's stock. but I don't have the stock airbox to throw on to confirm the turblance theory.
    Feb 2015
    Perth, Australia
    974
    set dynamic enable RPM and disable RPM to values lower than idle. then it will use MAF only fulltime
