Hi guys,
I'm trying to sort out my last little glitch in using TQ based decel and return to idle.
From 1500 rpm or higher, it returns beautifully to idle. Swift and smooth.
The issue happens when I decelerate (in gear) to under 1500 rpm, then kick in the clutch. It doesn't stall, but can fall to 400 or 500 rpm before recovering to my 800 rpm idle.
The throttle angle control seems good. The moment I kick in the clutch, the throttle starts to open.
The spark control seems weird. It has held a steady 12.5* advance during decel, but the moment I kick in the clutch, spark source changes from 'closed throttle decel' to 'tq control' and advance drops to about -6*, then bounces between 0-6* as RPMs fall. Finally at 700 rpm (100 below set point), spark jumps up to 17*. This is also the moment that torque source changes from 'tipout limit' to 'target N'.
Any ideas? Is there a table controlling 'tipout limit'?
Log attached.
