Lq4 stumbles and stalling
Did a mild tune on stock 04 Denali and after a couple weeks started ruff idle and stalling. Reloaded stock tune and same thing so started checking for other issues. Runs fine with mass air unhooked so replaced with a good one from my other truck and same issues. No codes and intake gaskets were done 2-3 years ago.
Check plugs... that will tell you what?s going on inside engine
Scan fuel trims and see if they trim similar
Like Ben said, "fuel trims". If it is running OK without the MAF I would guess that the MAF settings are a ways off.
fuel trims were a little out so I pulled the intake and cleaned it up. block sanded intake surface to ensure it was flat and installed new felpro gaskets and injector orings as a just in case. Now the trims are in range and runs much better but still has a light stumble and will stall after a few minutes but fire back up fine. it has the factory tune in it.
After driving it 20-30 miles and dealing with multiple stalls trying to get a good data log it has started running perfect. Not sure what was going on. Put tune back in it and all is still good.
