PE fueling not coming in
I have checked all the parameters for PE to enable and even added the PE switch to a file after this pull to verify that PE conditions were being met to enable and it switched to ON when I went to WOT. Please take a look and see if there is something I may have overlooked, I can't find anything that would account for the extra fuel to not be coming on....PE_conditionsmet_stillstoich.hptPEnotcomingin.hpl
PE TPS is not actual TPS u should be able to divide what u have by 4 then see if its how u like it, usually PE TPS of 10 is around 30% actual TPS, once u see where is triggers u can adjust to suit
I have it set so it takes progressively less input with more rpm. The problem I am having is even when I go WOT, through the scanner the switch for PE switches to ON but there is still no extra fueling being added to reach my commanded PE....
PE is working perfectly fine. It's just underestimating airflow by about 15-20%.
You need to tune VE and/or MAF
