Results 1 to 9 of 9
Thread: dyno flat at 6000-6500 rpms?
    Jun 2011
    Tucson, AZ
    295
    Hellcat 426 stroker. It is struggling in the high rpm range. I have a dual livernois fuel pump, boost a pump, 1300ix injectors. With a 10 percent lower and 2.65 upper it is only seeing 15 psi. It has a modern muscle ported throttle body. The engine builder thinks it is the throttle body. The tuner thinks maybe the stock supercharger is just too small for the stroker. It was tuned with Diablo. The car has 3.09s and a slightly shorter tire than stock. It was done in 5th. It should of been done in 6th gear. Automatic. Next week my friend is going to put it on the dyno and scan it with hp tuners.
    2016 Hellcat Challenger, automatic, black on black with brass monkey wheels
    10.13@ 140 DA 5000 feet
    2.75 pulley, tune, drag radials. 10 percent lower od crank pulley, 1050 ix. off road mid pipe. tune
    looks like you are hitting a limit in the curve and that boost is well a bigger motor on small supercharger. 2.65 and lower is around 18psi in good weather on a 6.2. Just FYI you spin it faster and up the shift rpm it is know to come apart the rotors dont like 25k to 26k blower speed.
    Dec 2016
    41
    15psi on that stroker and hellcat blower with those pullies is correct.
    Sep 2008
    Portersville, Pa
    289
    We've done numerous 426 combo's in the Hellcats. Stock fuel pump, ID1050's, upper and lower, stock TB, our custom "Demon Plus" cam, stock SC - no issues. We always run them on the dyno in 5th since none of our customers are going to be trapping at 200mph. I would guess that it is going flat due to a tuning issue.
    Specializing in building and tuning 1000hp, daily driven, 9 second cars!
    www.ostdyno.com Shop Phone: 724-368-9000
    Jan 2015
    On the dyno
    232
    Are you spraying this thing? What's up with the big jump in the curve?
    Jul 2015
    925
    Quote Originally Posted by curt@injected View Post
    V-tec kicked in......
    Jan 2015
    On the dyno
    232
    lol
    Mar 2018
    Illinois
    873
    Have you tried to search the forum?
    https://forum.hptuners.com/showthrea...ght=vvt+forced
    Tuner edgZ06's Avatar
    Mar 2005
    Pro Edge Tuning, CT.
    77
    That looks like KR pulled timing from 3600 to 4300.
    2004 GTO A4
    UNDER CONSTRUCTION....
    Previous E.T. 10.66 @ 130 mph
    http://www.mongillomotors.com/1066vid.html
    2008 G8
    LS3 76mm Turbo. 582rwhp
    2003 S600 Mercedes
    V12 Twin Turbo 21psi 600 rwhp
    2007 Factor Five GTM
    Twin Turbo forged LS6 600rwhp
    2015 Polaris Slingshot
    Tune & DR
    www.ProEdgeTuning.com
    Tuning with HPTuners & Mustang MD-1100 Chassis Dyno
    Wallingford, CT.
    [email protected]
