2008 Ford Mustang 4.6 GT
Hello
I have a 2008 Ford Mustang 4.6 GT and I have bought HPTuners Interface to Remap the ECU. After searching and trying several tables I coudn't find the main Fuel and Ignition maps. Only a Fuel map that works on under some correction factor because setting AFR to X it runs leaner that X and it is proportional.
Someone may have experience with this?
Kind Regards!
Santiago
May someone know something about this or recommend a tuner?
Regards!
Uh, the base fuel table is right here.
All the Spark tables are under the tab that says Spark.
If you don't know how all the spark tables work with each other, do some research. Use the search function on here and find out how everything works.
