If I pinned the ecm correct, have a good power and a good ground my flex fuel sensor should immediately be able to read the alcohol percentage pid correct? I was reading 9% in the scanner so I filled it up with a tank of E85 for tuning and it still shows 9% and my ltft were going crazy so I know the E was hitting the injectors. Any ideas? At first id read 0% and I uploaded the tune with the sensor enabled and it read 9%. I thought I was in the clear.
Yes we selected sensor not virtual and I just selected ethanol % for our scanner pid. Now I'm showing 6x% E so that seemed to be the trick but the cars is running super lean. Is there a table I would need to adjust for the fueling? If the car is reading Ethanol we should be fine right. I'll see if I can attach the scan but we are talking 11-21% lean right now but as I watch the fuel trims it seems to be sitting around 8-10
