I need some help, I have been trying to get this 2 to mach and I just can't the one on the left its right but the one on the graph its wrong and I don't know what I'm doing wrong.20181006_223307.jpg
You have to make sure you aren't logging the one bar map channel.
How can I do that?
Remove the channel??
You can't log duplicate channels and for sure you can't log a 1 bar channel and the 3 bar channel together. It will always skew the data.
Brah.
If you are logging the 1 bar map channel AND the 3 bar map channel, this is why you are having the issue.
You can not log both channels, remove the 1 bar channel.
Or do whatever
