hello guys after tuning my file successfully , still need to tune my ghost cam .
Fuel 95 octane .
My tuned file attached if some one can modify it for ghost cam tuning i will be thankful .
Thank guys .
Fuel 95 octane .
Thank guys .
Pretty old thread here and don't know if you've figured it out yet but you go into: Engine>Airflow>Variable Camshaft>Mapped Points. Find Intake Valve Opening and open that table. Set Mapped Point 0 and Mapped Point 1 to -40.00. Close that table. Now find your Exhaust Valve Closing and open that table. Set your Mapped Point 0 and Mapped Point 1 to 20.00. BOOM...DONE.
No you can not use the same angles from 11-15 on the 15-17 sir
Thanks for reply. I have cats so its a moot point now.
Lol. There's more to do to tune a good ghost cam than just boom and done.
Can you please advice how to?
Simple... Successful... Intelligent...
There's info all over the ford section.
Simply put
Increase idle rpm
adjust idle spark
Adjust spark torque ratio. s550s, this is the only way to change idle spark.
In the VCT tab, you need to increase your max advance/retard tables. You won't ghost cam if ivo is set max advance 0* at 800 rpm.
Your car could eference 3 different VCT modes at idle. All distance tables will need to request mp 0 at idle if that's your ghost cam mp.
Search 'how the distance tables work." You can Google it too. Its the first link.
Nice, thx
