Originally Posted by
evolmotorsprt
Thanks for the reply, I'm with you on most of what you said. I just want to check some math.
EQ=1.144 comes out to a lambda=0.874
That would mean @14.68, PE=12.83
and @14.32, PE=12.52
Does that seem correct?
I'm going to try EQ=1.16 and log today because I road race the car and want a little more safety factor at sustained high loads.
That should put me at lambda=0.862, and respectively @14.68, PE=12.655
Also, clarifying the PE torque trigger, do you set the "enable torque" to zero and then set "map" to 65-75kpa? What does this accomplish? are you doing this for feel or greater control?
Thanks for you guidance. I appreciate it.
