What is the Procedure to read a 2018 Hellcat PCN
I am trying to get the OEM file of a 2018 Hell cat with Hp tunner.
Unfortunately I only get a message of file can not be read.
Do you have the Smart Access cable? It is to communicate with 18 and newer cars.
No, I don't have the smart cable. Where does the smart cable connect? I only have the OBD2 cable.
https://www.hptuners.com/product/dod...-access-cable/
Im not certain where it goes. I do have a ZAutomotive Tazer with the Double Bypass so I can have OBD in the trunk area. It attached to a couple areas in the bus system in the trunk. It can also be used to tune 18 models. I just got tired of knocking out my Tazer from the clutch at the strip.
Do you have a modified PCM??
