Some nuances should be taken into account when choosing a lambda. But, to get to the truth, you should remember about factors that directly affect fuel consumption — these are weather conditions, driving style, tire pressure, and their condition, as well as the technical condition of your car.
It would be best if you also kept in mind the following nuances:
First, our cars' fuel level indicators show only the approximate value of fuel in the tank. And we need values that are accurate to tenths of a liter.
Depending on the angle at which we look at the arrow, we can also conclude the different amounts of fuel
www.cararac.com.
— The fuel level indicator will show the correct value only if the car is on a perfectly flat, horizontal surface, and this does not always happen.
— After filling the gas tank, many level indicators need time to adapt. Only after some time, they begin to show the correct value. Unfortunately, many car owners do not know about this.
