I am using an 04 ECM to run an 05 5.3l and everything seems to be working well except the charging system. I'm positive that the issue here is not with the charging system but rather the ECM or tune.
I know that there were some alternator changes from 04-05 but I don't know enough to know if it's something that I can tune around. If I recall, the ECM monitors voltage and calls for the alternator but I don't see any parameters around this in HPTuners.
Any ideas about what I should look for?
Readings when scanning are as follows:
DTC: P1637
Generator F terminal: 40-50%
L terminal: Always 'On'
Light: Always 'Off' (even though the light is intermittently off and on
