Results 1 to 7 of 7
Thread: Actual Throttle Position vs. Throttle Pedal Position
    Tuning Addict WS6FirebirdTA00's Avatar
    Jan 2005
    Concord, NC
    8,093
    Forgive me for going back to newbie questions here
    I haven't messed with tuning much over the last 7 years or so, at least none of the new stuff, not to mention the last big release I was using was 2.24. Trying to go back through my old stuff and searching without a lot of luck (lots of random hits).
    Anyway, I have a 2018 Sierra with the 5.3 and A8. I pulled the tune and took some logs to start familiarizing myself with the new stuff. I noticed the "Throttle Position SAE" was 83.9% for the "Accelerator Pedal Average" at 83.6%. When I hit the kick down button the pedal went to 100%, but the throttle position stayed at 83.9%.
    I tried to put in different PIDs to see what is going on/if I had the right PIDs. I did not see anything else that gave me 100% throttle position so I was curious what I am missing her. I always remembered with the Corvettes and trucks in the past was about getting the right PID. I was going to go back and try the non-SAE PIDs as I may have skipped over one trying them all out.
    While I am at it, can't seem to narrow down searches with good into on virtual torque which is new to me. Any links to share there would be great too
    Sulski Performance Tuning
    13,565
    This thread from 2005 should help.
    Most GEN 4 and GEN 5 vehicles is either 84% or 88% depending on computer. It seems everything after like 2006-2007 with the E38/E78/E92 etc used 84%.
    https://forum.hptuners.com/showthrea...2069#post32069
    Jan 2005
    Concord, NC
    8,093
    Thanks, wasn't sure how much they were alike. I remember the 88% from ETC cars I did back in the day, just not seeing the same PIDs/numbers and it was throwing me off.
    Apr 2005
    Sugar Land, TX
    1,198
    Try logging Commanded Throttle Actuator (Sae)
    Jan 2005
    Concord, NC
    8,093
    What are the parameters for actual throttle blade position and pedal position?
    Jan 2014
    Australia
    1,984
    these are what i use sort by ID number to find them
    ID# 2111 throttle body position
    ID# 2114 pedal position
    Jan 2005
    Concord, NC
    8,093
    thanks
