Yesterday i was working with a z06, the car is a 2015 manual, it has an AFE intake, kooks headers, o/r X pipe and a ATI 15% overdrive pulley, the owner wanted to get the max out of the car so we emptied the tank and put 10 gal of VP ms109 in it.
on the third dyno pass the car put down 625whp and AFR was the commanded 12.2-12.3 on the whole rev range, this is the log from it
dyno109oct3.hpl
On the 4th pass i decided to add a bit more fuel to get it to 11.9-12.0, as the knock sensor was pretty happy i added 3 more degrees of timing in the whole range, but the car didn't seem to like it as it put down 625whp again, here's the log
dyno109oct4.hpl
so i decided to take the fuel out again and leave the timing the same, but the car wouldn't start, there is fuel pressure and it has a very strong smell of gasoline so its not fuel, we disconnected the #1 cylinder spark plug wire and there is spark, but the car just kept cranking and nothing, in the scanner i can read RPM when cranking so its not the crankshaft sensor and no codes.
After a while trying it started using flood mode black smoke came out of the exhaust and there was a random misfire code, the car wouldn't idle and after that it wouldn't start again so we decided to change the sparkplugs, it started once again in flood mode this time white smoke came out and the fuel smell was so strong we had to get out of the dyno cell until the ventilation system got the smoke out.
So today i will be doing a compression test with a knot in my stomach as this could be the first time i hurt an engine and i dont even see anything wrong in the logs, so i decided to post this here and maybe someone more knowledgeable than me can see something off in the tune or logs.
tune2-109oct.hpt
this is the tune
