Page 2 of 4 FirstFirst 1234 LastLast
Results 21 to 40 of 64
Thread: Optimizing WOT TQ w/ VCT in Forced Induction
  1. #21
    Senior Tuner CCS86's Avatar
    Nov 2017
    Austin
    1,089
    I would leave the OP tables stock in a stock car, also would leave it stock for stock cams no matter the intake manifold/tb/cai combo. There's nothing to be gained.
    IVO/EVC tables are a different story.
    I also don't know what you are trying to say here. There are "OP tables" for a number of different aspects of the tune. We are talking about OP VCT tuning. The OP VCT tables define IVO and EVC angles, so you are contradicting yourself.
    This thread was started specifically for the purpose of tuning VCT for forced induction. I really don't care whether you or anyone else thinks stock angles on a stock car are ideal. Start a thread about that if you have an axe to grind.
  2. #22
    Nov 2017
    Austin
    1,089
    Quote Originally Posted by Thatwhite5.0 View Post
    It may be beneficial to let some of the hot gasses escape. Restrictions in your exhaust, mufflers, catalyctic converters, exhaust manifolds will have a different effect from car to car. This is still good data to collect. I've done the same to my 2012.
    These are the cam specs for first gen Mustang GTs.
    Intake Cam:
    Advertised: 263
    .050": 211
    Lobe Lift: .235"
    Centerline (Park / Max): 139 / 89
    Exhaust Cam:
    Advertised: 263
    .050": 211
    Lobe lift: .216
    Centerline (Park / Max): 123 / 73
    Valve events @ Park (no adv/ret) @.050":
    IVO: 33.5 ATDC
    IVC: 64.5 ABDC
    EVO: 48.5 BBDC
    EVC: 17.5 BTDC
    Total overlap (Park) @.050: -51
    Valve events @ Max @.050:
    IVO: 16.5 BTDC
    IVC: 14.5 ABDC
    EVO: 1.5 ABDC
    EVC: 32.5 ATDC
    Total overlap (Max) @.050: 49
    Good info, thanks!
    So is it generally accepted that overlap occuring at less than 0.050" of lift, is of no concern? Or could that still allow some blow-through under boost?
    Do we know what the parked overlap is at 0" lift?
  3. #23
    Curious to see what data if any people may have on the voodoo with Whipple and the 132 TB and long tubes. Where can I dig up the cam info to create a event map?
    higher intake pressure - more Intake retard - but with the high compression it might need spark retard or better fuel?
    retard Exhuast cam to reduce / eliminate overlap - Maybe a bit more than normal with long tubes? Is overlap always bad with boost? With a PD blower would you ever want overlap? Nothing to spool.
  4. #24
    Jan 2018
    202
    I have not had time to test however, basic knowledge would suggest that in turbo applications that had a larger turbine that has trouble spooling you would want no overlap at idle. Approaching the powerband you would increase overlap to achieve target boost pressure quickly and then taper off to hold that pressure and maximize cylinder pressure until the end of the RPM range. Obviously, you would need to take into account that you will have less time to get the same amount of air in the cylinder as RPMs increase so increasing IVO, enabling blow through logic in SD and minimizing the amount of actual blow through by modulating EVC would be best. We have one car at the shop that is in the middle of getting a new engine and centri so I should be able to give some logs and info soon after that one is done and on the dyno.
  5. #25
    Aug 2015
    San Antonio, TX
    179
    I’ll add my 2c here based on about 18 dyno pulls and about 6 hours at the dyno. I was NA at the time:
    1. Have all your test positions pre tuned so you can flash them and go, name them so you can tell where you are. 3 hours into tooning and its easy to loose your way and forget where you are.
    2. Log every pull and name the logs the same name as the dyno pulls. Do 2 pulls on the same toon if something is not right. Usually timing on the coyote is not identical one pull to the next.
    3. Log a lot of parameters because wheel horse power is not conclusive enough. Because timing and IAT can make comparing pulls difficult, you also need to compare MAF flow to try decide if one toon is better than another.
    4. Intake timing seems to make more difference, moving the exhaust didn’t seem to change anything for whp or MAF airflow.
    Then I went turbo and I haven’t retested cam timing, but seat of pants I can feel more torque from reducing overlap as rpm increases. But again, it’s hard to compare since the coyote will run with timing a couple degrees different each test.
  6. #26
    May 2015
    427
    Quote Originally Posted by superman07 View Post
    Yes, absolutely. A lot more than you would think.
    Quote Originally Posted by Plimmer View Post
    I'd recommend targeting a spark lead that will remain consistent, it's what I do. We know where MBT is at on the coyote, and instead of having the knock sensor interfere and alter the timing curve, target a slightly lower spark lead, one you know will not skew the results. Once you narrowed down your intake VCT that will follow VE, retard the exhaust as you stated. Add the timing back in, make small adjustments to the intake cam to confirm findings with added spark lead.
    Kris
  7. #27
    Nov 2017
    Austin
    1,089
    Quote Originally Posted by kris5597 View Post
    Kris
    Can you explain your reasoning here?
  8. #28
    Curious if overlap would require enabling the blow through logic. It is currently disabled on the whipple cal.
  9. #29
    May 2015
    427
    To not make it over complicated, after dyno testing and tuning, VCT results pointed to the PD loving overlap, more than a naturally aspirated setup, for comparison.
  10. #30
    Nov 2017
    Austin
    1,089
    It just doesn't make conceptual sense to me. I have no dyno testing to backup my intuition.
    To my knowledge, overlap helps in both getting out the last bits of combusted charge (better scavenging), and helping to initiate cylinder filling for the next event, using inertia from the exhaust flow.
    Better scavenging should improve power in any application, so I could see a small amount of overlap being helpful. But with positive MAP ready to fill the cylinders, even when cylinder pressure isn't very low, it's hard to picture overlap being much help there.
  11. #31
    Advanced Tuner bbrooks98's Avatar
    Oct 2011
    Gainesville, VA
    301
    Quote Originally Posted by CCS86 View Post
    That was my understanding as well. I was always under the impression that too much overlap on a PD blower you'd actually lose boost.
    Once of the things I've been meaning to setup since I'm turbo is getting some back pressure data and seeing how different amounts of overlap effect back pressure and if there is a power vs back pressure correlation throughout different engine speeds. I'm curious if that can be an effective vct tuning tool working with a smaller sized turbocharger.
    2011 Mustang GT TT A6
    1998 Eclipse GSX Awd
  12. #32
    Nov 2017
    Austin
    1,089
    Quote Originally Posted by bbrooks98 View Post
    Yeah, the turbo complicates the equation for sure! The method I laid out uses boost to infer the dynamics of the system. But, when exhaust flow is actually developing your boost, the logic breaks down.
  13. #33
    May 2015
    427
    Like I said, don't overthink or complicate it. Just test it for yourself and see what you find.
    Kris
  14. #34
    Jan 2015
    On the dyno
    232
    I prefer to sweep them on the dyno and then overlap the graphs to find the ideal angles. Some set ups can take 40 pulls or more. I usually shut off all knock retard and advance and start with a safe spark number so that it doesn't influence my results.
    There are some huge gains to be had if you have the patience to do it.
  15. #35
    Apr 2018
    605
    Are we sure there is nothing to be gained on a stock engine with these OP Angles? -40 Intake from 1750 to 4000, and 15 exhaust from 3k+ .. Surely these blanket angles can be optimized but how much is it worth? Sorry for bringing up N/A in your thread OP but it was discussed here and I love to theorize
    Prior to me buying HPT I spoke to VMP and they told me there were significant untapped gains to be had in the lower RPMs (not so much at peak) @ WOT on a bone stock coyote..... Any truth to this?
  16. #36
    Jan 2015
    On the dyno
    232
    There are gains to be had stock on some of the 11-14 cals, but not on anything 15 and newer. At least not much
    Quite a few of the 11-14 cals have some low rpm torque that can be had with vcm tuning.
  17. #37
    Nov 2017
    Austin
    1,089
    Anyone know this?
    ThatWhite5.0 shows it at -51* overlap, parked, @ 0.050" lift
  18. #38
    Apr 2018
    605
    Anyone know this?
    The way I had figured it out @ 0" lift was -0.5 true overlap @ Park if the specs I saw were accurate on the stock cams (11-14).
    -51 overlap is correct @ .050"
  19. #39
    Nov 2017
    Austin
    1,089
    Quote Originally Posted by blackbolt22 View Post
    Interesting. So, it takes essentially 50* of crank rotation to move from exhaust valve at 0.050" lift to intake valve 0.050"?
    I was searching around for a good valve even calculator. This one seems pretty good, but I can get the settings to match the posted specs. It seems like the "advance" field needs a negative value to to allow an intake centerline value higher than the exhaust (but it won't allow it):
    https://mgispeedware.com/camshaft-calculator/
  20. #40
    Nov 2017
    Austin
    1,089
    According to this simpler calculator, we are just barely into positive overlap, while parked, at zero lift:
