Results 1 to 6 of 6
Thread: Hesitation stock 6.0
    Apr 2018
    18
    When going from cruise at around 40-50 KPA then going to WOT which is 90kpa or better and feeling a slight hesitation in throttle input and actual acceleration would adding some fuel in that higher kpa range fix that
    Dec 2008
    Nevada
    4,452
    Typically you tune your tables in then adjust transitions with the enrichment rate ramp in. What is your enrichment rate value? I adjust mine to show resulting transition afr in the low 12's as starting points.
    Have a tune and log to post
    Apr 2018
    18
    Unfortunately not right now done have my computer handy
    Apr 2018
    18
    Enrichment rate value is 1.3
    Dec 2008
    Nevada
    4,452
    thats a decent value. im curious to see what the transfer afr is on a log
    Sep 2009
    764
    I would look at PE fuel delay time and RPM as well as minimum load value to enter PE. You can rypically go WOT and not get PE for up to 60 seconds on some of the trucks.
