Results 1 to 9 of 9
Thread: 6R80 4th gear engine speed limit
    Hi
    I went into issue, above 7000 rpm engine hits rev limiter when i want to shift above 7000 engine RPM. All limiters of course ar much higher and it only applays to 4th gear. Looks like it's hitting some hidded rev limit. No problem when shift points or manual shift are done bellow 7000rpm.
    Eastern and Central Europe American Muscle and Harley-Davidson tuning
    www.hd-customs.pl
    http://www.facebook.com/hdcustomspl
    Feb 2017
    TX
    444
    Is anticipation disabled in transmission general? Post your file.
    I tried with enabled with different values and disabled also, no luck, no matter what i do and shift points are above 7000 engine rpm in 4th it happens and getting engine rpm limit.
    www.hd-customs.pl
    Did you found it
    No. I found also if there is more power, limit comes earlier.
    www.hd-customs.pl
    Are you able to help vee four
