Results 1 to 5 of 5
Thread: 2018 F150 3.5L can i license PCM only and not TCM
    I have a bunch of friends with these trucks that only want to disable autostart/stop . Can I Just use a $100 license for PCM only and not read or flash the TCM?
    Mar 2010
    Texas Hill Country
    3,299
    yes only ecm
    Advanced Tuner Auto-Hentzschel's Avatar
    Sep 2015
    Schleid, Germany
    341
    if you will license only the PCM, you need only PCM read! if you read PCM and TCM, you always nee 4 credits for licensing
    Jul 2018
    33
    If all they want is the auto start/stop disabled, I would use forscan. It is totally free and a quick Google search will show how disable the start/stop.
    Mar 2018
    22
    Easiest way to do it is just disconnect the connector of the battery terminal. Unclip the connector on the positive terminal and leave it off. Or forscan like wveryone else said free program and $20 ms/can obd2 cable
