Edited for new info/tune/log in the posts below.
Hey folks - new to the forum here and need some input and help.
Here is my setup - Jeep CJ7 with a 2007 LY6 motor (from Tilden Motorsports with their harness) - E38 ECM - NV4500 manual transmission - No VSS
Here are my issues:
It will not rev past 4000 rpm (bucks like it is hitting the rev limiter). This happens when in neutral or under load while driving.
I have searched extensively and have found several references for this issue:
https://forum.hptuners.com/showthrea...-past-4000-RPM (which is pretty helpful) and has several responses from the HPtuner folks
and
http://www.masterenginetuner.com/limp-mode-page-2.html
I have taken the Jeep to Ellis at Speed Secrets in Monroe Washington (who seems well regarded) and he has tried several tune changes to fix this including using the settings described in the other threads (Fuel Cutoff DFCO settings/torque management settings/P/N rev limiter/gear rev limiter etc). This appears to solve the problem for a short time, but it always returns - no rev past 4000 rpm.
Ellis is forwarding me the tune to provide it here.
I have a VSS pulse generator that will work from my mechanical transfercase speedo output. But I have no way to feed that to the TCM'less ECM.
Any thoughts or strategies to fix this would be greatly appreciated. I'm stumped.
Thinking a bit outside the box on this, could I swap ECU's to solve this (as the LY6 in the Yukon never came with a manual transmission). And if so, which one to chose? I'm not opposed to ditching the VVT aspect of the engine (though I'd prefer to avoid that cost of a VVT delete/cam swap if possible).
