Results 1 to 6 of 6
Thread: 02 sensors after lt install
    Sep 2018
    8
    I just installed long tubes now the 02 sensors aren't reading anything. Also on scanner it's not showing injector data. I've tried 2 sets of sensors.
    2016 Camaro
    16 SS A8
    Quicksilver Detailing
    13,564
    Post log.
    Sep 2018
    8
    Forgot to put I've got the driver's side plugged into rear location, the extensions that the shop ordered was wrong.
    13,564
    Well, the primary o2 sensors won't read right if you are using the rear sensor locations and plugs.
    Sep 2018
    8
    Both sensors are the upstream, just the drivers side is plugged in to the rear. I knew it wouldnt read right just have it like that untill the right extension comes in. But it's not reading anything.
    Have to wait till tomorrow to post log
    Sep 2018
    8
    Had to rig up an extension for the drivers side.
    Needed to repoll scanner and everything is reading, now if I could get it running right like before the headers. I didnt think I would have to change up alot after the install but car is running like crap
