so, to start i bought a 2011 Camaro 2ss with a Huron single turbo kit. I bought it at a small dealership, as is. The only thing they could say about the car was the gas didn't smell normal and thought it was E85. I drove to the nearest E85 gas station put in enough E85 to get to emissions, plates and home. Car doesn't seem to have issues driving around.
My questions start, as I opened up the tune I saw the stoich AFR was changed to 12 all the way across, why is this? The spark timing tables have changes for E85, I think? Also, when I look at the maf scale why would I want more than one cell with the same flow numbers? When I compare to a stock maf its less than a 5% increase which I thought from N.A. to E85 was another 5% to 8% more? The aem wideband is in gas. I do understand a wideband only thinks in volts from stoich and the gauge translates so 14.7 gas is really 9.02 E85, they are both 2.34v. The wideband does not seem to be wired into the a.c. or e.g.r. input.
I have not yet driven the car hard because in my datalog you can see I am running out of fuel pressure starting at 3000rpms so I do plan on dropping the tank to see what I have and decide where to go from there.
I have so many questions about this tune. Is this just a base tune? Are these good changes to this tune? Why would the stoich be changed from a scale to just 12 afr? Will this tune work if I install and enable a flex fuel sensor? Are the changes even for E85, was it to run gas or race gas and a turbo? I'm sure more questions will come. Attached is the tune and a data log. Any input is appreciated.
Thank you for looking and commenting.
