Results 1 to 4 of 4
Thread: Ls3 crate motor and gm computer running lean
    Jun 2018
    42
    After 20 to 30 secs of idle, the STFT go to 32%+. The oxygen sensors are working and switching good; what else can I check?
    Sep 2018
    36
    Check for vacuum leaks or exhaust leaks
    Apr 2013
    Honolulu, HI
    24
    Where's the MAF and what size pipe? Depending on location and pipe size it will throw off MAF Cal. If no vacuum\exhaust leaks like stated above then give it the fuel it wants and see how it responds
    need logs all mods even down to intake tubing size and oem flash . So post oem tune and post a log with wideband and eq error with and without closed loop active and post with always resest fuel trims
