Results 1 to 20 of 33
Thread: How do I log AFR with MPVI2?
    I just purchased a MPVI2 and am wondering what methods I could use to log AFR. I have an Innovate gauge with external outputs and am not sure how that would connect to the MPVI2. I have a GM vehicle
    Sep 2006
    Syracuse, New York
    299
    I don't believe the module meant for logging external data is available quite yet for MPVI2
    28,261
    MPVI 2 currently doesn't accept external inputs, you'd need to find some other means.
    Sep 2006
    Syracuse, New York
    299
    What vehicle? On many GM cars you can use either the AC Pressure circuit or the EGR input to log wideband
    Quote Originally Posted by HackAbuse View Post
    It's a 2013 Buick Regal Turbo but I was hoping for something a little more sophisticated than wiring it to one of the ECM pins. I thought the MPVI2 had this ability and am disappointed that it does not.
    Senior Tuner mowton's Avatar
    Mar 2007
    Florida
    3,773
    You can utilize the AEM 30-0334 WB and use the OBDII interface they provide on all 2008+ vehicles. Another option is to use a PLX or the above AEM WB and use the Serial Interface. This will require some rs232 to USB conversion using an off the shelf cable and some wiring to the WB to DB-9 mating connector.
    Ed M
    [email protected]
    Quote Originally Posted by mowton View Post
    Ed,
    Not to hijack. But have you tried using the 30-0334? I had a chat with AEM support that say it may work with older vehicles but they don't have any success stories. Do you own one/have tried one?
    And is the update rate with the serial option fast enough, or any more accurate than the analog method? (I've been trying to find a way around voltage offsets and getting better accuracy than logging analog via EGR)
    Mar 2007
    Florida
    3,773
    Quote Originally Posted by scoob8000 View Post
    Ed,
    I have the 0333 which the only difference between the two is the 0334 is also EFI Live compatible. And yes, I have heard that there is a possibility it may operate on some 2006/2007 platforms but not LS1 platforms. I haven't tried it on any pre 2008 though. Maybe some other users have and can chime in. Dr Mike has a way, but as of now it is not available.
    The serial/OBDII interfaces are fast enough and accuracy is the same. As you said, there is no offset issues with these options.
    Hope this helps.
    Ed M
    [email protected]
    Ed M
    So, the AEM 30-0334 plugs into the OBDII port? Or is there another access point? If it does plug into the port, how would you then plug in the MPVI2 to log the data?
    13,559
    It's a pass through dongle if I'm saying that right.
    It has a OBD2 female and male end on the same unit, so the MPVI cable plugs directly into it.
    That's how I was envisioning it. I guess it's not compatible because it outputs a different protocol than the LS PCM's, and HPT can only listen to one or the other?
    Mar 2007
    Florida
    3,773
    With the LS1, you can utilize the EGR or AC Pressure input at the PCM to connect an analog wideband output and manually develop transform math based on the widebands output values which you will find in the manual. Use our calculator to define the values and create a math parameter. We also posted a video on out You tube channel (ERM Performance Tuning) showing how to set up this math and Scanner Graph. https://www.youtube.com/watch?v=Ru_2M2uGSKs&t=46s
    Ed M
    [email protected]
    Aug 2009
    Calibrating
    3,373
    Kind of a slight pain, but been using my mpv1 pro as a datalogger and mpvi2 to write tunes
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen 5 Viper
    OK everybody, I had total success and here's what I did: I purchased the recommended AEM 30-0334 WB and MPVI2 and followed this tutorial https://youtu.be/ozJz-pNFCuo and can now log AFR on my laptop. I haven't tried doing it with Bluetooth connection yet but was already able to log without the cable before and expect that adding the AEM gauge will not change that.
    Jun 2018
    Australia
    15
    how is this done?
    Mar 2007
    Florida
    3,773
    Quote Originally Posted by marksawatsky View Post
    The AEM X series WB will allow interfacing to a 2009 and up platform through the OBD II port. It may also work on some 2006-2008 platforms but that you will have to try.
    The only methods available for 2008 or later platforms is either the EGR/AC Analog approach from above or I believe either the AEM or PLX will work through the serial interface introduced during 3.0 release.
    Ed M
    [email protected]
    Mar 2007
    Florida
    3,773
    Quote Originally Posted by rpm4740 View Post
    how is this done?
    https://forum.hptuners.com/showthrea...eband-how-to-s
    Ed M
    [email protected]
    Jun 2018
    Australia
    15
    And this will still work with the mpvi2?
    Jul 2018
    13
    As Bill@HPTuners said in post #3 "not available yet"
    "proprietary Expander Hub ready for analog / digital / voltage sensor and device inputs."
    I believe this is part of the PRO Feature Set to be announced..
    Update*[ I stand corrected! Thank you mowton! Glad there is a way! ]
    Mar 2007
    Florida
    3,773
    Sorry missed you question....Yes it will work. So will the AEM OBDII interface for 2008+ platforms.
    Ed M
    [email protected]
