Results 1 to 3 of 3
Thread: Throttle Position Sensor getting clipped at 50 in Scanner playback
    Mar 2017
    Santa Rosa
    99
    I did a test run, saw the TPS value while recording up above 75% a couple of times, but, when I get back and zoom in, the value is cut off at a max of 50% for the entire run. You can see the table tops in the graph.
    What is causing this?
    Peter
    Peter Young
    1966 LandCruiser FJ40 with 6.0l Gen 3 vortec and 4L80E.
    1984 LandCruiser FJ60 with 5.3l Gen 3 vortec, Magnusen supercharger, and 4L60E
    13,559
    You are logging 2 TPS channels, remove the non SAE channel.
    Then maybe try it again.
    Mar 2017
    Santa Rosa
    99
    Thanks for the help, had no idea I had two.
    Peter Young
